Editing Genesis 2 Female MAT
tititlemot
Hi guys,
I love Genesis 2 Female "Bree" character skin color, but I'm a little bit disappointed with her only 3 make options (6 with "no brows") & too bright nipple color. And the questions are:
- Can I manually edit & create several new MATs based on Bree's so I can have some option (new makeups & several darker nipple colors)?.
- Is it possible to use GIMP to do it?
- Or is there any product or expansion for Bree's makeup?
Every respond & answer are appreciated
Thank you guys.
Post edited by tititlemot on
The make-up options are separate head textures so there isn't much you can do about them. Ideally make-up options should be PNG or TIFF formats with transparency so they can be overlaid on the base texture using LIE (Layered Image Editor) built into Studio. Bree has a no genitalia torso texture map that could be layered over the with genitalia map in GIMP than play around with opacity and blending options until the nipples look right to you, you may want to do that to the SSS torso maps too.
I see. What about if I use LIE Baker? I tried to use Skin Builder, but I didn't like the result. Well, I guess I have to do some post works then. :)
Thnx for the reply jestmart!
