Hair prop does not conform to morphed figure (please help fix this)
I have a gens hair prop that will not conform to Dicktator on a morphed figure. Obviously can't post screen shots, but here's the breakdown:
- Hair prop WILL conform to gens when loaded on a genesis 8m dev load (daz asks to adjust fit for unrecognized character, even though it's designed for g8m)
- The same hair prop glitches when loaded to a figure with body/gens morphs applied. I've also tried loading it to the dev load g8m and re-fitting and parenting it to the morphed character, and it does the same thing.
- The morphs in use are a mix from dicktator and third party creators.
- I've had this issue crop up several times with props for dickator, so it's not just this one hair product. Any suggestions on how to get the prop to conform to morphs would be appreciated!
Check that the morphs you are using are set to AutoFollow - click the gear on the slider>Parameter Settings and it will be a checkbox.
