New User Question: Handles
hdbiker60hdbiker60 Posts: 7
How do I use the evening star dress? Wahat are the handles on / off files used for?
    edited February 2015
    Are you using this with Victoria 4?
    Handles are used for posing, for seated poses, and other extreme poses. The handles off pose (PZ2) is used to hide the handles for rendering.
    You also do not seem to have the DS materials installed as well, you only appear to have Poser materials which would need fixing for DAZ Studio. The Product page says :
    This product has a full product installer and an additional installer with DAZ Studio optimized MATs
    You need to install that file as well.
    Post edited by JimmyC_2009 on
  • hdbiker60hdbiker60 Posts: 7
    Yes, I try to use it for victoria 4.
    Also, the techno Tabby v4 a4 does not work on victoria 4, it does nothing! Any hints?
    Are you sure that you are loading the clothing, and not just the texture for it?
    The clothing itself will be in Figures (CR2), if you are trying to load a PZ2, then that is just a material change.
    OK, so PZ2 is the material.
    But where is the clothing for those materials?
    http://www.daz3d.com/techno-tabby-v4-a4-elite
    They should be under Figures.
    Poser Formats > My DAZ 3D Library > Figures They should be CR2 files.
    If you installed using DIM, then go to the Installed tab, locate the item, right click on it, and select 'Show Installed Files', that will show you where everything was installed to.
  • fixmypcmikefixmypcmike Posts: 19,708
    The clothing should be in "Content Library > Poser Formats > [library name] > Figures > TechnoTabby-V4”. To apply the materials, go to "Content Library > Poser Formats > [library name] > Pose > MAT Techno Tabby” to get the DS-optimized materials.
