Smart Content, Content Library tabs
in The Commons
I am unable to rearrange the tabs on the left now. Did something change?
The Content Libary and Render Settings tabs used to be 2nd and 3rd on the left, but they mysteriously dropped to the bottom of the list.
In the past when this occurs, I just click and drag back toward the top, but now that does nothing.
(If I remember correctly) You may have your panes locked.
This may help
https://www.daz3d.com/forums/discussion/233446/how-do-i-undock-and-close-a-pane
Once you have it set to how you like it you need to save the way it is. That way you can reload when stuff like this occurs.
It's not a docking issue I'm having, I just want to rearrange the tabs, so that the most used are at the top.
I don't know why DAZ Studio randomly moves them, but in the past all I had to do was hold the mouse down on the tab and move it up or down to change where it appears. Not the entire pane, just the tab order.
Yes I know, but in the past it was as simple as holding the mouse on the tab and sliding it up or down in the list. Now it no longer works.
Unfortunately things get changed...: (
I may be wrong, but I believe when the panes are locked you can't reorder them. The above link tells how to unlock them. I'm not at my pc now or I would have checked it before posting.
OK. Gave it a try and that worked.
You are right that you cannot move them unless the panes are unlocked.
Somehow I might have accidently locked them. Ctrl-U is the shortcut so maybe I pressed that somehow.
