dForce c1 Spiky Short Hair does not render in iRay - sometimes?
I am using the dForce c1 Spiky Short Hair on a Genesis 8.1 female. The hair will occasionally stop rendering properly in iRay after having successfully rendered in the same scene, without having changed anything about the hair or the figure. Even opening a scene which rendered properly already and changing nothing, the hair disappears. Any ideas, anyone?
  • GordigGordig Posts: 10,678
    dForce hair doesn't render if certain tools are active, most notably the geometry editor. Hit Alt+Shift+U and try rendering again.
  • LeanaLeana Posts: 12,991
    Other tools which could cause dForce hair not to render include the joint editor or mesh grabber.
  • JJDJJD Posts: 10
    Thank you all! That was exactly it - I had the geometry selection tool selected. That was driving me up the wall, thanks!!
