Trouble with product (solved)
MilosGulanMilosGulan Posts: 1,988
I got this product https://www.daz3d.com/topmodel-updo-hair-and-oot-hairblending-2-0-for-genesis-3-female-s some time ago and now after some time I figured that some shaping preset does not work, it might be a bug or it is just my mistake... Anyway here is the picture, and shaping presets from 14 to the end does not work. On the picture I tried to apply preset 18 and You can see result. I cant get that shape no matter what, tried with surfaces and morphs too...
Please can someone help me with this. I really would like to learn to use it or see if it is maybe a bug.
Post edited by MilosGulan on
  • felisfelis Posts: 6,137
    Not sure what to say.
    Any shape I apply changes the hair.
    Attached image is with shape 18.
    Have you looked in the log to check if any errors when applying, and/or have you tried an acutal render?
    1200 x 900 - 1014K
  • MilosGulanMilosGulan Posts: 1,988
    edited September 2022
    Ok thanks for the answer, yes it works on G3f, but I have converted it to G1f, and unfortunately it does not work that good with mentioned shaping presets...  Here is best result I could make with G3f clone for G1. Now I wish if it has support for older figures... I really love it as it is really one of the best hairs I have used.
    Thanks for the answer, it solved my problem yes
    501 x 600 - 526K
    What I will suggest, is to NOT fit the hair, but just parent it to the head.
    You might want to scale the hair, if the G3/G1 has (very) different head size.
    Autofitting removes all the bones and if the shaping options rely on the bones, they don't work anymore.
  • frank0314frank0314 Posts: 14,784
    If you do all your adjustment first and get it to where you want it and have no plans on changing it I guess you can parent it, thought not ideal.
