Please Help! Clicked the wrong thing and now Daz don't work
So in the middle of posing I clicked something that said " UV Map" (?) while trying to change views from the view menu. it was the lowest-most option under that tab. It opened a whole new pane that showed all the scenes i had saved as little icons. I clicked "Close Pane" thinking that would close these little icons and I could get back to posing. Now the pane is all grey and I can't see anything on it.
Please help. :(
Hay! I've never done that. However, when panes and things go goofy, it has been known to set things right by changing the Workspace to something else [like Hollywood], and then change it back to what you want. Resets the tabs back to default settings.
That totally worked. And I would have never thought of it. Thank you!
You're quite welcome, glad to hear it worked :-)
FWIW, the next time you accidentally do this, all you need to do is drop down the same menu that gave you the UVmap option, and select what you meant to click on.
Your view pane vanished because the UVmap view wasn't a new pane on top of the old one, it was the same one you were looking at before. When you closed the new view, you closed the old view.
Well, I forgot exactly but I don't think it was an option anymore after it was clicked.
