Soo A
Was it intentional that the product catalog uses the same image for three different products?
The Soo A bundle, the Soo A character, and the Soo A hair all apparently use the same image, which comes across confusing and a disservice to the product itself.
I hope this isn't a standard going forward?
Sending an inquiry.
Anyone else having an issue rendering the Soo A hair? The front part renders, but not the back part. Not sure what to do about it.
I am having the same issue with this hair. I have searched all over but have come up with nothing in the way of a solution.
I figured out the reason the hair renders/previews only the face and not the head section. I created a figure using a Genesis 8.1 base. I applied all the shaping and then added a texture map for the skin. The skin I applied was for a Genesis 8 figure. Since the hair is created for 8.1 and the head is handled differently for Genesis 8 maps, the hair will not work properly. Once I applied an 8.1 texture map the hair worked correctly. I made a texture map for the hair using a G8 template and now am able to use the hair on G8 figures as well.
TLDR: The hair only works correctly on G8.1 texture maps.
Only one thing left to do about problems with Soo. Sue!
