Lock a keyframe pose
rickfoxxx74331700rickfoxxx74331700 Posts: 186
edited February 2015 in New Users
When I apply a pose on a keyframe, automatically the preceding keyframes pose the figure with halfway poses. So my question is: Is it possible lock a keyframe pose? I tried using "Edit>Figure>Lock>Lock Selected nodes" but I cant get.
For clarity, I attach two pics. I want the first sequence(Keyframe1=Keyframe2) but I get the second sequence, with that halfway pose when I apply pose on keyframe 3.
I'm using Daz 4.7 and animate.
Thanks in advance.
Post edited by rickfoxxx74331700 on
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,249
    I would just copy the pose from Frame1 and reapply it to Frame2 and hit the + to add it as a keyframe. Daz naturally creates a transition between keyframes for animation, So you don't want to have a setup where
    Frame1-Keyframed Pose<--------Empty Frames------->Frame3-2ndKeyframedPose </p>
    You want to have Keyframes side by side on the timeline or KeyframePose1Keyframepose1(again)then in next frame Keyframepose2.
    Hope that makes sense :)
    Post edited by Design Anvil - Razor42 on
  • Richard HaseltineRichard Haseltine Posts: 108,650
    You can also change the interpolation type - casual has, I think, a free script to do this or you can use KeyMate/GraphMate from the store.
  • rickfoxxx74331700rickfoxxx74331700 Posts: 186
    Thanks for respondig.
    Interpolation mode - Constant is what i'm looking for.
    Thanks
