How to animate with BOOST?
Hey guys, so, been trying out BOOST for the last few days. Now, they say you can use it for animation, but so far, I can't get it to work. I set it up according to the directions for animating scenes but the thing either crashes or no frames render.  I set max time sec to "0" in the progressive rendering section,  problem is, even when  I set the render update intervals to my desired frame render seconds the render just keeps going as if I am rendering a still.... can anyone give me a heads up on what I could be doing wrong? Thanks so much, appreciate yah!  Alicia
  • Not to discourage anybody who wants to answer, go ahead. But I think you'll find faster live help via their ticket system that is set up in Discord, during their normal working hours.
  • TotteTotte Posts: 14,779
    For animations to render using Iray Server you need to use Streaming and not Queuing.
  • Luv LeeLuv Lee Posts: 230
    HI, thanks for your answer--I do use the streaming part...
    I went to them first--the answer I received was kinda confusing honeslty.
    Well that would be discouraging :-(  Thankfully Totte came by with the answer :-)
