These rings...
Looking for these rings but having a hard time finding them. Specifically the swirly bits with the gems. I've searched everything related to jewelry and nails but starting to think they are part of a set or perhaps from a figure? Thank you in advance.
  • SofaCitizenSofaCitizen Posts: 2,144
    It could also be that they are not actually rings? There is only a ring part on two of the three fingers and the other just has the swirly bits with nothing to actually hold it onto the finger - also the ring part is on different segments on the other two fingers. Therefore that may actually just be a red herring and the swirly bit is like a brooch or something that is just copied 9 times and placed against the fingers?
  • JOdelJOdel Posts: 6,322
    It's entirely possible tht this is a kitbash using one ring multiple times, scaled and repositioned. The actual band is probably a seperate matt zone, usually hidden.
  • 3Diva3Diva Posts: 12,024
    What product is the screen grab from? That might give us more clues.
  • Thanks all. I've seen these swirly nail bits in use other pieces as well. This is a kit bash. The smaller bands, the ring with the little moon for example, is from a set I already own. I think the swirly bits are attached to the fingernails. This grab was of someone else's art so I hesitate to post the full image, but I am pretty sure these are designed specifically for the fingers.
  • DaventakiDaventaki Posts: 1,624
    edited September 2022
    These remind me of the body jewels that someone sells on Renderosity but im not sure if thats where its from.  I am currently looking for them but I cant for the life of me remember who made them.
    Change of ideas because I found the art on Rendo its by Maddelirium but it was made in 2020 so the products I was thinking of are more recent than that I think.  I did send her/him a message but the chances they remember might be slim.
    Post edited by Daventaki on
  • Thank you for doing that Daventaki, way to spot that art. I'll be curious to know what you find. Initially I thought they were by Fabiana, but I don't see them there. They also remind me a bit of Arki's products, but no luck there either.
    Your welcome, I looked through Arki's stuff also because the face jewels are by them but no luck either.
    Check Fabiana's store over on rendo. It may not be the same, but 'll bet you ccan find something that could produce it.
  • LeanaLeana Posts: 12,996
    I might be wrong but to me these look like a texture on some gloves rather than actual rings.
  • I found another piece by a different artist using what appears to be the same product! I will message them today and update.
  • beachlegsbeachlegs Posts: 526
    Post edited by beachlegs on
  • Oh wow!!! Mystery solved. Thank you Beachlegs! ❤️❤️❤️ Big hugs to everyone who chimed in to help.
