Multiple Duplicate Formula List
xyer0xyer0 Posts: 6,333
edited August 2022 in The Commons
I finally tired of the Duplicate Files message prompt that I had to OK for G8F to continue loading, and I went through the Parameters listing to note which morphs had a parenthetical numeral beside them. Since I'm gonna file tickets for each of these (yeah, I know), I decided I would post my list here to save someone else the trouble searching or buying.
Muscularity Morphs for Genesis 8 Female(s) has multiple duplicate names with Musculature HD Morphs for Genesis 8 Female
Daz Originals' Genesis 8 Female Body Morphs conflicts with Handspan Studios' Genesis 8 Female Body Morph Resource Kit 3  (Love Handles & maybe one other morph)
Colm Jackson's Ultra Face Morphs - 60 Essential Faces for Genesis 8 duplicates files with Aisling [DO/RedzStudio], Alana [DO/Akasha/Anain], Cara [FWSA], Cassidy, & Sorcha [Belladzines]
"Lara" pits Thorne VS DO/Anain/Belladonna
"Natalie Head" is shared by FWHP VS 200 Plus Head Morphs
"Nora" fights between Cherubit & Adiene/Vex
"Rose" is CherubitFWSA
"Tara" is Kayleyss VS DO/TristanLiu/YCFCG (the "8" was added to her name a few days after her release) THIS CONFLICT MAY BE DUE TO A G3F CHARACTER CONVERSION. I'LL CHECK AND UPDATE IF SO.
Post edited by xyer0 on
  • I assuem you mean Duplkicate Formulas, not Duplicate Files? Having duplicate labels (which is what you are seeing in the Properties pane) is not the same issue. To identify one of the pair (usually) responsible for a duplicate formuilas error you need to check the log file, then work out which other morph or property uses the same name.
  • Where you get clashing labels, in the Parameters pane option menu (the hamburger/lined button in the top corner) turn off Preferences>Consolidate Properties to get separate sliders for each and you can either use them that way or use Parameter Settings, acessed from the gear icon on the slider, to relabel one of them and save that as your preset for loading the figure pending a fix.
  • xyer0xyer0 Posts: 6,333
    edited August 2022
    Thanks once again, @Richard Haseltine, for the help. In a couple of cases, files (for skins) seem to have been overwritten by another, and there is no way to access them both. Is there a quick workaround for this?
    I'll check the log the next time I load G8F.
  • If files are clashing like that then the only fix is to edit one of the presets and the filenames to match.
    OK. I've tried that before. A couple of times. I haven't gotten it right yet. I'll just start uninstalling until or in case Daz fixes them. Thanks again, Richard, for your service.
