Auto-Fit not working right on G8M
When I fit an item to G8M I don't get the option to choose the type of item. Any idea what might be broken and how to fix it?
Oddly they work perfectly fine for 8.1 Male, but I still mostly use 8 due to working with a lot of legacy characters and shells dependent on the older UVs.
Post edited by Psyckosama on
reinstalled Genesis 8 male. No effect.
How do you install your content?
Manually.
Have you imported the metadata? AutoFit uses the Content Management System.
I don't believe so. I just did a reinstall of daz and just pointed it at the old folders.
How would I do that?
In thwe Content Library option menu (the lined/hamburger button in the top corner, or right-click the tab) select Content DB Maintenance, then check Reimport Metadata; the next dialogue will show any userdata it has found, exported from previous versions if the files have been copied across, and any product data, assumign you included that in your manual installation.
That fixed everything. Thanks.
