mixamo error
mixamo is not working with freemon daz3d plugin anymore i just checked it today
something updated in mixamo and the new animations files downloaded fromt here no longer show up correctly in daz3d and so the plugin does not work anymore
if anybody more skilled here knows anything and can help me fix it will be really thankful :)
  • mixamo ascii fbx used to show up properly in daz3d before i will add some images here to show how they used to show in daz3d
    old files are still working properly but anything downloaded today from mixamo is giving error and showing up like above pictures
    2084 x 846 - 178K
    3687 x 1927 - 1M
  • Yes would be great to have a fix on this
  • wolf359wolf359 Posts: 3,936
    What is the "freemon" plugin?
    its a plugin for daz3d to use mixamo animations easy with one click
    it used to work properly and easily for last 1 year but few days ago mixamo and daz3D ASCII .FBX file import is giving an error so the plugin is not working anymore
    Is the developer stil active?? perhaps they could update it.
    i emailed the dev he replied and says his plugin is working fine ( which it is if you use old downloaded files from mixamo )
    but new files downloaded from mixamo doesnt work or even get imported properly into daz3d ... you can test it yourself download mixamo ASCII .fbx file and import it in daz3d it will show messed up
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,280
    edited September 2022
    cannot find but wasn't that Free Nomen or something similar, the Facemotion  capture guy
  • Bump post removed
    yes thats the guy i bought the plugin from his website
    but the thing is plugin is working fine still with old downloaded files its the mixamo update that messed up daz import system
    if you download a ASCII from mixamo today and import it in daz3d it will show up messed up and with errors
  • jonbapjonbap Posts: 15
    Interesting, I just downloaded some Mixamo animations today with plans to use the Mixamotion script I bought from him a few months back, and was dismayed to see it won't work.  At least now I know I'm not alone, and you are right, old animation files will work with it but I could download the same animation file today from Mixamo and no luck.  I've sent the developer an email with an attached animation file that I downloaded since the apparent change at Mixamo, hopefully he will look into updating his script because otherwise it is useless and was a massive overpay for me since I only downloaded four or five animations before this issue has come up.
    I'll post if anything new comes to light, if anyone else learns anything or discovers a work around please let me know.
  • CriosCrios Posts: 3,002
    Just for ignorance, but isn't possible load directly Mixamo file in DAZ, without plugin? I0ve see that export in FBX and DAE.
  • Happened to me as well, I think there is some update on the Mixamo side and it's no longer compatible with DAZ, hopefully future DAZ update can fix this
  • trojanx97trojanx97 Posts: 51
    no fix yet
    talked to mixamo guys on their forums and they blamed daz software
