dForce Romantic Gentleman Outfit
I bought the dForce Romantic Gentleman Outfit for Genesis 8 nd 8.1 Males. There is no content. The download was 6.8 MG's.
  • There do seem to be issues with the two outfits from the Regency bundle - we have reported this.
  • jjoynerjjoyner Posts: 762
    edited March 2023
    @Richard Haseltine
    Richard,
    I bought the Romantic Gentleman Outfit dForce Clothing for Genesis 8 and 8.1 Males (SKU 87103; https://www.daz3d.com/romantic-gentleman-outfit-dforce-clothing-for-genesis-8-and-81-males) yesterday and installed it today with DIM.  The pieces of the outfit load fine but I cannot load all of the Iray materials.  I can apply the materials for the boots and pants with no problem, but I cannot apply four of the five materials for the shirt, four of the five materials for the waistcoat nor the materials for the coat.  When I try to apply the offending materials, I get the same error – “Error opening file – An error occurred while reading the files, see the log file for more details.
    For example, I opened a new file, loaded the coat (RG Coat.duf) and then tried to apply the Purpur material (Purpur Coat.duf) to it.  The action failed; below is the info in the Help file.
    Do you know if there are unresolved issues in the product.  The product page states that the product is compatible with DS 4.21.  Should I submit a ticket?  Thanks.
    2023-03-15 20:37:24.176 [INFO] :: *** Scene Cleared ***
    2023-03-15 20:37:43.359 [INFO] :: Prepare asset load (open): /People/Genesis 8 Male/Clothing/Romantic Gentleman/RG Coat.duf
    2023-03-15 20:37:43.359 [INFO] :: Locking viewport redraw...
    2023-03-15 20:37:43.365 [INFO] :: Viewport redraw locked.
    2023-03-15 20:37:43.449 [INFO] :: Native format content directories: 4
    2023-03-15 20:37:43.449 [INFO] :: Poser format content directories: 3
    2023-03-15 20:37:43.449 [INFO] :: Other import format content directories: 1
    2023-03-15 20:37:43.449 [INFO] :: Begin asset load (open): /People/Genesis 8 Male/Clothing/Romantic Gentleman/RG Coat.duf
    2023-03-15 20:37:43.549 [INFO] :: *** Scene Cleared ***
    2023-03-15 20:37:43.549 [INFO] :: Determining missing assets...
    2023-03-15 20:37:43.829 [INFO] :: Setting textures...
    2023-03-15 20:37:43.830 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5665): Node parent not found.
    2023-03-15 20:37:43.897 [INFO] :: Scanning for addons...
    2023-03-15 20:37:43.957 [INFO] :: Creating node geometry...
    2023-03-15 20:37:43.977 [INFO] :: Creating UV sets...
    2023-03-15 20:37:43.977 [INFO] :: Creating materials...
    2023-03-15 20:37:44.207 [INFO] :: Resolving legacy figures...
    2023-03-15 20:37:44.207 [INFO] :: Preparing modifiers...
    2023-03-15 20:37:44.208 [INFO] :: Creating modifiers...
    2023-03-15 20:37:44.479 [INFO] :: Applying animations...
    2023-03-15 20:37:44.479 [INFO] :: Finalizing modifiers...
    2023-03-15 20:37:44.479 [INFO] :: Finalizing simulation providers...
    2023-03-15 20:37:44.479 [INFO] :: Sorting property groups...
    2023-03-15 20:37:44.480 [INFO] :: Setting up follow targets...
    2023-03-15 20:37:44.480 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(2149): Failed to follow node.
    2023-03-15 20:37:45.052 [INFO] :: Finished asset load (open): 0m 1.603s - /People/Genesis 8 Male/Clothing/Romantic Gentleman/RG Coat.duf
    2023-03-15 20:37:45.231 [INFO] :: Unlocking viewport redraw...
    2023-03-15 20:37:45.231 [INFO] :: Viewport redraw unlocked.
    2023-03-15 20:37:46.059 [INFO] :: Loaded image: AKRGcoatinner1.jpg
    2023-03-15 20:37:46.309 [INFO] :: Loaded image: AKRGcoatinnerTRS.jpg
    2023-03-15 20:37:55.388 [INFO] :: Prepare asset load (merge): /People/Genesis 8 Male/Clothing/Romantic Gentleman/Materials/Iray/RG Purpur Coat.duf
    2023-03-15 20:37:55.388 [INFO] :: Locking viewport redraw...
    2023-03-15 20:37:55.388 [INFO] :: Viewport redraw locked.
    2023-03-15 20:37:55.504 [INFO] :: Native format content directories: 4
    2023-03-15 20:37:55.504 [INFO] :: Poser format content directories: 3
    2023-03-15 20:37:55.504 [INFO] :: Other import format content directories: 1
    2023-03-15 20:37:55.504 [INFO] :: Begin asset load (merge): /People/Genesis 8 Male/Clothing/Romantic Gentleman/Materials/Iray/RG Purpur Coat.duf
    2023-03-15 20:37:55.663 [INFO] :: Determining missing assets...
    2023-03-15 20:37:56.412 [WARNING] :: Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
    2023-03-15 20:37:56.412 [INFO] :: Error loading asset: H:/My DAZ 3D Library - Passport/people/genesis 8 male/clothing/romantic gentleman/materials/iray/rg purpur coat.duf
    2023-03-15 20:37:56.412 [INFO] ::   Operation failed
    2023-03-15 20:37:56.517 [INFO] :: Unlocking viewport redraw...
    2023-03-15 20:37:56.517 [INFO] :: Viewport redraw unlocked.
    Post edited by jjoyner on
  • zombietaggerungzombietaggerung Posts: 3,856
    edited March 2023
    Did you have the clothes fitted/parented to the correct figure? "Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found." means that for the materials to work the pieces have to be parented to the correct base figure. In this case, G8M.
    Post edited by zombietaggerung on
    @zombietaggerung - Thanks much! You solved my problem.  I was loading the clothing without any figure just to see how the outfit and its pieces looked.  Loading a G8M allowed the materials to be applied.  I need to learn more about hierachical materials.  Again, thanks!
