Adding to Cart…
I know someone probably has dealth with this and can't find it myself. But when I add HS dforce V2 I get double breasts. One for the default then the pair with physics. Have done this before and it works but for some reason today I can't make it work. In the last picture I changed the surface base color for hs dforce from white to black so you can see the difference better.
1st: Select model
2nd: Add Dforce Modifier: Dynamic Surface
3rd: Merge HS DFBV2 0Genesis 8 Female Material / Genesis is selected
4th: Merge HS DFBV2 1Breast for G8F v2 / Genesis is selected
5th: Merge HS DFBV2 2Apply Matching Materials for Breast / HS Dforce is selected
6th: Shows double pair of breasts
Edit: I figured it out. I had the geometry editor active when adding the dforce modifier.
Please put the Viewport into Smooth Shaded mode, ore remove textures, if you need to show an exposed figure.
The G8F and G8.1F HS dForce breasts seem to have a default-shaped frame regardless of breast morphs applied. This frame shows in glowing green and is only visible in iRay rendering (whether separate rendering or viewport in iRay mode). Even if you set the geograph to invisible the green frame displays in iRay. There's no such problem when using HS dForce breasts on G3F. In the attached picture I applied about 50% "Breasts gone" and placed a dark gray plane through the center of G8F to make the green artifact easier to see. Is anybody else seeing this? I see it on two different computers, including a brand new computer with the very latest versions of all software.
I am suddenly getting this too. No idea what happened as it was fine a couple days ago. Did you ever figure it out?
Figured it out. Need to click the eye to hide HS Dforce Breast Addon after you run the simulation. Dforce still works but it hides the blue lines. Not right but it does work that way.
I followed the tutorial and this is what I get. I don't know if I am missing something or what but I followed the tutorial.
Hey! Could someone please re-upload this hotfix? The link is no longer valid.
Only the creator may upload or share the file, unless there is a readme with the original files saying otherwise.
