Unreal Engine Importer Plugin Missing
barbie
I have installed the Daz To Unreal plugin for Unreal Engine 4 and I’m having a little problem. I see the option to export to Unreal Engine from DAZStudio, but when I switch to Unreal Engine I don’t seem to have the importer plugin. I checked the plugins folder for Unreal Engine and it got installed in /Users/Shared/Epic Games/UE 4.27/engine/plugins/marketplace. Any advice?
I am using:
macOS Monterey version 12.4
I had the same problem previously. I had made the mistake of using the Daz to Unreal plugin that is on the Epic Launcher, and not installing via the bridge inside Daz.
Delete the plugin from the Unreal folder, and from the exporter inside Daz Studio, click Advanced Options and reinstall the bridge to the same marketplace folder. From there, inside Unreal, you should find the plugin ready to be enabled via the Plugins menu.
Edit - I just saw your screenshot, so I can see this is what you did previously. If Daz is doing it's thing, then the issue must be on the Unreal side.
