Does DAZ Make A Lot Of Log Entries?
3DSaga
[Does DAZ Make A Lot Of Log Entries?] The reason I ask this, is my C drive is filling up rapidly. My desktop PC is mainly used for DAZ, and some very light web browsing to DAZ related sites. It's the first desktop PC I have purchased that isn't purpose built- it's a Dell Alienware that I purchased in the spring of 2020.
I've pared back much of the bloatware that comes with "off the shelf" PCs, though I'm still running the Alienware maintenance software.
Each time I finish up with the DAZ, before shutting off the PC, I check the status of the drives, and C drive always has less space available. It's a 250 GB M.2 NVME PCIE drive. I have never experienced this on any of the PCs I have owned, and I tend to keep my computers far longer than most people.
A quick web search for solutions resulted in recommendations to check on software that makes an unusual amount of log entries, which is why I'm asking if anyone else has experienced this as they run DAZ.
The Daz Studio log size is capped. 250GB is not a large drive, whata re you installing/saving to it?
DAZ 3D, DAZ Studion 4, and DAZ Library are saved to my D drive, a separate internal 2 TB drive. All of my work is saved to an external 4 TB drive.
Where is your Daz Studio database and cache?
Barbult, I'm not sure; are those with the DAZ files in the Programs folder on C drive normally?
Yes, in Daz Studio, go to Edit>Preferences and look at the CMS Settings tab. That will tell you where your database is. Mine is in C:/Users/Barb/AppData/Roaming/DAZ 3D/cms. I think that is the default location (your account, not "Barb", of course!) I've never tried moving the CMS database, but I'm sure you should not do it while either Daz Studio or DIM is running. Richard Haseltine could tell you how to do it, I'm sure. Definitely don't just delete it!!!
In Edit>Preferences, look at the General tab. There you will see the location of the Temporary Files and DSON Cache Files. Mine are on C, again in my account's AppData.
Barbult, thanks for this info! I'm definitely going to try to move the Temporary files and the DSON Cache files.
IF one has Headshop, one has to [or had to] leave the Temporary Files location at default.
