Do I have to re-install?
The battery in my laptop exploded. Fortunately, all of my DAZ stuff was located on an external drive so nothing was lost. When I run DAZ, all of the content is there and is working. However, when I run DIM, it isn't finding anything and wants to re-install 7000+ packages. How do I tell DIM that the stuff is already there?
  • felisfelis Posts: 6,152
    It is the manifest files that tells DIM what is installed.
    You need to point DIM (in settings) to where you manifest files are,
  • MelanieLMelanieL Posts: 7,815
    edited August 2022
    Sounds like the manifest file may have been on your C: drive (that's the default place) and hence went up in the big bang. That's is why I keep mine on a different (external) drive, like the downloaded files. Do you have a recent backup from which you can recover them?
    Post edited by MelanieL on
  • Drogo NazhurDrogo Nazhur Posts: 1,295
    I had copies of everything on the external drive. I just changed the path and I'm good to go. Thank you.
    yes Good for you!
