World Recenter script - feedback sought
chris-2599934
I've finally dipped my toe into the world of Daz scripting and written my first one. Here's what it does...
There are rendering errors that can occur in Iray if a character is too far away from the world origin. Eyes can turn black. Strange marks show on scalps. Maybe other stuff too. So what I've written is a script to move the selected object to (0,0,0) and everything else in the scene stays in the same place relative to it. The only thing that doesn't move is the Perspective View position (is it possible to move that via scripting?).
I've tested it, and it seems to work, but I'd appreciate a once-over from more experienced eyes. Is there anything that I've missed?
// DAZ Studio version 4.10.0.123 filetype DAZ Script
// Define an anonymous function;
// serves as our main loop,
// limits the scope of variables
(function(){
// String : A function for retrieving a translation if one exists
function text( sText )
// If the version of the application supports qsTr()
if( typeof( qsTr ) != "undefined" ){
// Return the translated (if any) text
return qsTr( sText );
// Return the original text
return sText;
// Define common message variables
var sButton = text( "&OK" );
// Get the selected nodes
var aNodes = Scene.getSelectedNodeList();
// Get the number of nodes
var nNodes = aNodes.length;
if( nNodes != 1 ){
// We're done...
MessageBox.warning( "Please select a single item in the scene before invoking this script", "Selection Error", sButton, "" );
return;
var oNode = aNodes[0];
//Offset is the selected object's position, less any origin positioning
//This should give the same figures that show in the X/Y/Z Translate properties
// (for unparented items)
var vOffset = oNode.getWSPos().subtract(oNode.getOrigin());
var aAllNodes = Scene.getNodeList();
var nAllNodes = aAllNodes.length;
// Iterate over the nodes
for( var i = 0; i < nAllNodes; i += 1 ){
// Get the 'current' node
oNode = aAllNodes[ i ];
// If the node is a root node, move it by the offset amount
// if it isn't, there's no need as it'll move with its parent
if (oNode.isRootNode()) {
var vNewPos = oNode.getWSPos().subtract(vOffset);
oNode.setWSPos(vNewPos);
// Finalize the function and invoke
Post edited by chris-2599934 on
Although Perspective View isn't a selectable camera in the Scene list it is a cam,era and can be manipulated (as a DzNode) like any other http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/camera_dz . To get it you need to get the Dz3DViewport for your active view and use getCamera() http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/3dviewport_dz (ulitmately, http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/viewportmgr_dz from the MainWindow, then get the active viewport from that and the 3D Viewport from that).
Remember to acknowledge and link the source when using one of rob's sample scripts, as noted in the license terms.
*HOW TO ACTUALLY USE THIS SCRIPT* (Let go of your hair and breath)
Copy all of the text in the quoted box and paste it into a text editor like notepad or anything that's simple. Save it as [whatever you'll recognise].dsa into the following directory ==> Wherever you're PUBLIC Documents are/My DAZ 3D Library\Scripts\Utilities\MoveScripts. The most important thing is the file extension. It MUST be ".dsa" (Dot Dee Ess A). The other suggestions are just to make your life easier. So that after you refresh your resources or just x out daz and start it again, you can find this dashing young scholar and god amongst men's life changing/hair saving script and you can quit pulling your effing hair out over this black eye issue.
Just felt like it would he helpful to add this instruction here, since I'm an uber noob who was just about to join an Ahmish community and shun all technology forever over this gee dee cee essing seemingly unfixable and never to be patched render ruining bee effing bug. Had I not already spent like a grand on content for this program, I would have given up after a few hours. Fortunately I persisted and found a link to the estemed appostle chris-2599934's here's great gift to all of humanity.
We need a tip feature for people like Chris. I'd seriously give him a hundred bucks right now.
great job ! the time I was wasting to create a group, then unparented etc... thank you very much !
and thanks to w00tus for the explanation ;)
again thank you :)
Buy him a gift card in the Daz Store and send him the gift card code in a PM.
I installed the script now, because I launched a new scene and... I am unsure how it works.
I loaded a G8F to hope it will spawn in the world centre.
When I select that and use the script nothing happen, when I select the camera over it and launch the script this happens:
(I selected the G8F AFTER using the script with camera selected). The camera got spawned with default settings,
So now is the G8F -400 under the zero Point, is THAT what is called World centre O_o
And what do I have to select to get the best result?
The script want that I select atleast anything.
Please help me :)
The script moves the world center to be wherever the selected object is.
So, for example, add a G8F to your scene, and move her away from world center - e.g. x=500. Create a camera looking at her, and maybe add some other elements to the scene. Look through the camera you created.
Now select the G8F and run my script. It will rearrange the scene so that the world center is at her position. All the other objects will be in the same position relative to her, so you should see no change in the scene, except that the world center crosshairs will appear at the G9F's origin. This version of the script doesn't move the Perspective View, so you'll see everything move if you're looking through that instead of an actual camera.
You converted the G8F into a G9F nice! :D (typo joke!)
So... not the elements does move, the world does move?
And what if I have 2 cameras?
Both cameras move. Basically, everything that you see in the scene tab will be moved along with the recentered figure so they're all kept in the same place relative to eachother.
I used the script now, because the pins got so big and the eyes of my char got really black :O
But there was one thing I forgot: Unlock the cameras or they will NOT follow ;) But I could easy reposition them.
btw. I would change the thread name to "World Centre Script" or something, I wanted to use my browser cache search and did then remember it was something about "my first script" and not about World centre.
That others see it faster ;)
Godd idea. Done.
Hey, I hope youre looking in this thread :D
To use the script correct, do i need to unlock everything?
I get atm my "too far away" problems.
I wanted to use your script, selected my "main Char" and used it, then I had the feeling nothing changed, I moved something (if I remember) and then did dasz Studio just crash :o
I use a Big police station so its a bit hard to find a good centre :(
Hi the script seems to have 2 problems.
1. it does NOT move locked things (cameras, walls etc).
2. its NOT undoable (bad if you forget to save...; I did^^)
The first problem is really bad... so I would have to unlock ALL! and some objects should not be unlocked because there is a reason, why I lock them :/
Is it possible you can fix it?
@chris-2599934
Edit: for some reason does it move some items, but not all, even locked ones.
Maybe... it moves groups but not single stuff?
See attachment, the Construct is 1 cube +5 instances (duplicated the 1 cube) and textured.
any idea why that cube did not got "catched".
I assume because it was the ONLY LOCKED thing outside of a group.
Here is a version that moves locked nodes
Thanks, I will save it and try when I get the time.
Tested: Good thing: it works!
Even MORE good thing: you can UNDO it, that was the problem with the first script, you had to reload the full scene to undo it.
So your script is better in 2 ways!
Bad thing: feeling a bit bad about Chris, like betraying him^^....
Thank you so much for these scripts, helped me out big time today.
Have a very large scene, and i was having issues with hair caps and black eyes.
All resolved :)
Damn! This thing really works! Thank you!!!
Thanks for the script, just saw this yesterday, and tried it. However, I found a problem, if there are some cameras in a scene, set them to a camera group, after run this world recenter script, all cameras in the group are weird, can not rotate around the aimed object as normal, the orbit track is weird and difficult to control.
It cost me 2 hours to find out what is the problem, finally I found it is because the camera group has its own none zero coordinate. Even not use this script, as long as you set some cameras as a new group, the orbit problem happened.
So here I add some content to OMNI's script, to fix camera group problem:
Don't know why, but JS code appears in one line in this forum. If anyone want to see it, just click ' "QUOTE ', the whole codes will appear in your comment box, copy and use it.
But still, I wonder why setting a new camera Group will has a none zero coordinate, and why this none zero group coordinate will affect all its cameras' orbit rotation track, is this a Bug?
This is absolutely the most useful thing I've ever found on the forum. I had NO idea what was causing the black eyes. I had often had the problem, and just recreated the scene by saving it's in bit's and pieces - not realizing that I was probably just resolving the location. Now, one click, WOOOOOWWWWWW. Thank you!!!!
Can we have the final version in a clean formatting please? :)
@second_technician_rimmer_9571136c47
Code formatting on the DAZ forums has been broken for quite a few months now. If you click the button to quote functions post, it will load the properly formatted version in the "Leave a Comment" box at the bottom of the page and you can copy the code from there.
Whoa.. so I discovered the same issue when rendering an image tonight and stumbled across this thread.
I just wanted to say thank you heaps for this script hey. It's well and truly sorted the issue out from what I can tell so far
Wow, just discovered this script and am so annoyed that I had missed finding it much earlier. Thank you!
me too thanks to you
I have a scene with a spotlight parented to another node. The latest version of the script from function didn't reproduce the lighting correctly. Interestingly, the original version of the script from chris-2599934 did reproduce the lighting correctly. I don't think my scene has any camera groups or locked nodes to worry about. I wonder if one of the fixes for those issues caused the problem with the parented spotlight.
Oh dear, even worse, when my selected object was inside a group, the whole scene looked different. Objects were scattered all over the place. When I tried a group containing just a camera and a G9 character (G9 character was selected), after applying the latest version of the script, the character was completely distorted. Internal anatomy flew all over the place. Maybe I didn't copy the script text properly, or maybe it does not handle grouped or parented objects properly. The original script at the beginning of this thread continues to work OK in my scene constructions.
This is still not respecting the license terms for the sample(s) used as a starting point. Please correct this.
