Daz stops using my GPU if I open any popup menus.
I have been having a problem, if I start Daz Studio, load a scene and render the GPU is used correctly, I can add items to the scene move them, change parameters and everything go well. However if I open any menu, like Save Scene afterwards Daz starts rendering in CPU only, my GPU keeps at 0%, I have to close Daz Studio, opening it again, load the scene I just saved then the render uses the GPU, does anyone knows a workaround for me to not have to exit everytime I use a menu? I attached a Screenshot of my Settings
Any menu or any menu that writes a file? If the latter it sounds as if it is related to the OpenGL thumbnail render. What Drawstyle are you using in the Viewport?
