[Solved] How To Preserve The Wire Mesh Before and After Transfer Utility
JamesJames Posts: 1,177
edited August 2022 in Daz Studio Discussion
Hai guys, I have a problem.
my clothing wire mesh is changing after the transfer utility.
Is there a way to preserve it?
I use 8GF based mesh.
Post edited by James on
  • felisfelis Posts: 5,945
    Is it fitted to the base character?
  • Does the distorition go away if you zero the figure's pose (Edit>Figure>Zero>Zero Figure Pose)? If so, and if you are going to dForce the clothes (or at least the skirt part) this shouldn't matter in use - getting a sensible response from skirts etc. if theya re rigged to the legs is not really possible, though smoothing the weight maps and adding JCMs can help.
  • JamesJames Posts: 1,177
    @felis is fitted.
    @Richard
    Wow... zero pose does make the distortion go away.
    Thank you.
    It's going to be dforced.
