[Solved] How To Preserve The Wire Mesh Before and After Transfer Utility
James
Hai guys, I have a problem.
my clothing wire mesh is changing after the transfer utility.
Is there a way to preserve it?
I use 8GF based mesh.
Post edited by James on
Is it fitted to the base character?
Does the distorition go away if you zero the figure's pose (Edit>Figure>Zero>Zero Figure Pose)? If so, and if you are going to dForce the clothes (or at least the skirt part) this shouldn't matter in use - getting a sensible response from skirts etc. if theya re rigged to the legs is not really possible, though smoothing the weight maps and adding JCMs can help.
@felis is fitted.
@Richard
Wow... zero pose does make the distortion go away.
Thank you.
It's going to be dforced.
