Strange arches on feet
Hi All,
I need your help,
My Genesis8.1 character has got strange arches, see attached image.
When I zero the whole character, they return to default, but, I dont want to reset the whole character.
(I want the feet back to the genesis 8.1 default, the rest of the character must not be changed).
When I select a foot, and try to zero just the selected object, it doesnt change.
any suggestions ?
  • That looks like a morph that si saved with a non-zero default value, so it is always applied, or if there is a pose applied it might be a JCM (to adjust the shape when posed) that is kicking in even when the figure shape it goes with is not applied. Do you see the arch deformation when the pose is zeroed? Does it go away, even if the figure is posed, when you zero the shape?
  • joostjoost Posts: 11
    Deformation is still there after pose is zeroed.
    Only when I go to 'edit -> Figure -> Zero' and zero the figure, its restored. (but all the other modifications on the character are gone too)
  • I assume that Zero Figuer Shape also works - if not it suggests that there is more than one issue with the property that is causing this.
