FSL Bashable Backdrop questions
Just got this product. The first time I booted it up I was able to apply materials and shaders to it, now it seems it won't let me do that at all. Is there something simple I am missing? I'm clicking on the prop but there are zero options coming up for either shading or materials in presets.
Are you using Smart Content, and you are not getting the options to load the presets with the prop selected? That could be a problem with your database not displaying correctly, or not running at all.
You should still be able to see, and load, the Presets from the Content Library Pane > DAZ Studio Formats, or the Products option in the Content Library pane as well.
In order for shaders to load and work correctly, you need to select the object in the Scene Pane, AND the Surface you want to apply the shader to in the Surfaces Pane.
