Need help with Poser…Please help.
Ok I have V4 and M4 both with their Morphs ++ files. How do I get there respective morphs in the same runtime so they will work in poser. As of now they are in separate folders and will not work when I load them into poser. The bodies of each figure do not change and nothing happens. I'm using a mac...So in the M4 base library folder you have the idaz, character,materials, and pose folders. Which m4++ files do I put where to have them show up in poser as well as work in poser. Thanks Larry
  • fixmypcmikefixmypcmike Posts: 19,696
    All the morph packs need to be installed to the same place as the base figure -- the important part is the files under "Runtime:Libraries:!DAZ:Victoria 4" and "Runtime:Libraries:!DAZ:Michael 4" -- they have to all be in one runtime to work properly.
  • edited December 1969
    Does it work if you add the runtime with the add runtime tab in the poser library...
    You want the morphs installed in the same runtime folder as the figure you're using.
    No, all morphs must be in the same Runtime.
