Character parameters do not default to zero.
This happened to me once before to another character. I fixed it but can't remember how I did that.
This character I put into zero pose. But his body part parameters do not default to zero for some reason. I used "Alt+click" on each parameter after using the "Zero pose" and this is what it looks like at the supposed default.
What can I do?
Thanks.
  • felisfelis Posts: 6,504
    It looks like you have memorized another pose.
    You should be able to Edit > Figure > Zero > Zero figure pose. That should bring it back to default. And then you could memorize that pose to get it all back.
  • Richard HaseltineRichard Haseltine Posts: 111,390
    It may also be that there is a Pose Control set on the figure node, which is affecting the bends on multiple bones.
  • vollezarvollezar Posts: 27
    Thank you both.
    I also remembered that I can save the morphs, then load fresh model for the character I used and load the saved morphs. That also worked.
