Cant see a thing
Well thats not true, i can see, the problem is that as i am getting older my eyesight is not what it was. My problem is that the text on Daz is very small and difficult for me to read, even with glasses. I can't seem to find a way to increase the size which is making life pretty difficult for me. Can anyone help please
Is that the text on DAZ 3D; the site or Daz Studio (DS); the program
Sorry, should have been more specific, its the DS program. On the site i can simply do cmd/+ to enlarge test
thanks for that tip as i actually struggle to read the forum
hope you find a solution
The style setting "Main street" has somewhat larger text. You could try swapping to that one. Window/style/select style/Main Street. You can adjust colors etc if you need to as well.
Thank you but i already use Main Street, didn't realise the text was larger but hey...thanks again
Well piffle! I know that at one time people would create more interfaces and that everything is changeable including colors, text size and type. How this is done I have not a clue in the world.
There is no facility that I know of for changing text size inside DAZ Studio.
The only thing that I know of to make it bigger, is adjusting your monitor screen resolution, or get a bigger monitor, which was what I did :)
Im surprised there is no apparent way to help with this problem. However because the obvious is seldom apparent to me, and that has nothing to do with poor eyesight, adjusting screen resolution does the job. Thank you very much JC ...;-P
You are most welcome!
I have mine set a bit bigger than most people would use, my sight leaves a lot to be desired these days.
I bought a bigger monitor as well, they are not as expensive as they once were, I am getting used to it now, but it took a little while :)
I moved that up my "going to have to get" list just the other day. I needed to use a split viewport and everything just looked tiny when I did.
