Problem with Particles 3
Quietrob
I tried to relocate an effect (cr2) with Particles 3. I can't find a way to change it's location. Thus I have to build my scene around the Particle Effect rather than create my scene and put the Particles 3 CR2 where I wish.
Does anyone that has Particles 3 know how to relocate the cr2.
Thank you.
As an answer I've found that I can move each particle to a different location using the transform dial. However my goal is to move the BODY of the special effect character. Moving 50 or more individual particles can be tedious.
If Poseworks or anyone else can up with an answer or knows of update, your help would be appreciated.
Answer found! Please consider this one closed.
I realize this was 9 years ago but what did you come up with? I have have the same issue.
Hey, Night Owl 3D,
I was going through old stuff and stumbled across Particles 3 in my Runtime. I was having a similar problem and then realized all I had to do was parent the figure to the emitter for moving around and then I parented the emitter to a primitive for scaling and other manipulations. Hope that helps!
