Timeline Symbols
Good day everyone-
Can anyone tell me what the difference is between these symbols in the timeline?  Both of these key markers will NOT delete from the timeline no matter which options I try (object, node, node recurse, or prop).  This isn't the same buglet from 4.12 is it??
Thanks!
  • Richard HaseltineRichard Haseltine Posts: 109,252
    The triangles are containers for frames on sub-proeprties, the Ts are standard TCB (smoothly interpolated) keys. To delete are you seelcting them first (e.g marquee select) then right-click and choose the removal option?
  • Hi Richard, thank you for responding!  I did not try right-click until you mentioned it; but alas it did not work either (pic 2).  I was going to the bottom of the timeline and using the delete button (pic 3).  I suspect they are the exact same command process.  Not sure what's up with G8F, but that's where I am seeing this.
    461 x 496 - 92K
    238 x 56 - 4K
    You haven't yet selected anything to delete - click on a single key or drag to select multiple.
  • In my example, the selection was small..  I selected the "T" properties under the menu...
  • Would you show the selection as well, just to make sure it looks right.
  • jjoynerjjoyner Posts: 774
    Miss Animated said:
    Good day everyone-
    Thanks!
    In follow up to Richard's first replyt, the WP Guru discusses the Daz Studio timeline in several of his YouTube videos.  A short one that may help you here is Showing keyframes for Parameters, Properties and Morph Dials in DAZ Studio which can be found at .https://www.youtube.com/watch?v=lCxhMidbs_w
