Make Non Zero Float Node Properties Considered As in-Use
mCasualmCasual Posts: 4,607
edited July 2022 in Freebies
Sometimes i select Aiko's head after 'shaping' it
i do "Memorize-selected-item" then "clear-animation of selected item"
and this makes all the current properties values their default value
so even if this value is keyframed at that value at frame zero ...
when you go in the parameters tab,
all properties are considered not-currently-in-use
this script keyframes all parameters that dont have the value 0
only floating-number parameters like the Blink property for example are touched
and it's a very light touch, the "default" value is multiplied by 0.999
this is enough to make Daz Studio consider the properties as Currently in use
var node = Scene.getPrimarySelection();
if( node ) {
var n = node.getNumProperties();
for( var i = 0; i < n; i++ )
var prop = node.getProperty( i );
var val = prop.getValue( 0 );
if( prop.inherits( "DzFloatProperty" ) && ( val > 0.0001 ) )
prop.setValue( 0, val*.999 );
Post edited by mCasual on
  • Silver DolphinSilver Dolphin Posts: 1,640
    Nice Thank you
  • mCasualmCasual Posts: 4,607
    edited July 2022
    makes it easier to find the properties you use(d) without scrolling down a grayed out 2ft long list :)
    oh and that's the head pose i proceeded to make after using this script
    Silver Dolphin said:
    Nice Thank you
    3840 x 2160 - 7M
