Convert DForced plane to a static prop?
DiomedeDiomede Posts: 15,410
edited July 2022 in The Commons
Greetings.
Simple question.  I created a new primitive plane with a high number of divisions.  I applied a DForce modifier to the plane.  I draped the plane over a cubic object to get a tablecloth effect.  I want to save the draped plane as a new static prop for future use as a ghostly tablecloth.  Eerie?  Anyway, I can't find a menu that has 'convert DForce object to prop,' or similar.
Post edited by Diomede on
  • GordigGordig Posts: 10,677
    Export as OBJ.
  • FirstBastionFirstBastion Posts: 8,056
    Gordig said:
    Export as OBJ.
    Exactly, and then reimport into Dazstudio and save as a prop asset.
  • DiomedeDiomede Posts: 15,410
    Thank You.
    This solution, while effective, is less than elegant.  I will put in a suggestion to include a 'convert DForce result to static object' menu option in the next update.  Seems like something that would be a common desire.
  • FSMCDesignsFSMCDesigns Posts: 12,851
    Diomede said:
    Thank You.
    First time I have heard anyone express a need for this. I export as OBJ all the time, it's pretty straight forward
    edited July 2022
    In my opinion, FSMCDesigns has given the best argument FOR a hot-key or menu options which converts a DForce result to prop, not against it.  'I export as OBJ all the time...'  While there is no 'need' for such a menu option or hotkey, it would be a convenient thing to have, and people would 'use it all the time.'
  • felisfelis Posts: 6,152
    In my view, there is much more relevant things to focus on for Daz developers.
    If you really has the need, maybe a PA can do a tool for that.
    Or you could use this tool to turn dForce into a morph https://www.daz3d.com/dforce2morph
    And if you saved the plane with the morph loaded, it should be as good as a static prop.
