Cube controls
Is there anyway to flip the cube controls to be on the left intead of the right side of a viewport? Even in the docked view all the controls still reside on the left and get covered up everytime I access my aux views and all the panes sitting on the right of my screen which I am constanly accessing.
  • I've used three monitors since the early 90s (that was with macs)
    for some reaon I can't post pics here right now...
    center monitor has nothing but viewport with 2 in wide scene file to the xminus side
    monitor on my right side has nothing but content library
    monitor on my let side has two sets of panes one closest to big screen (center) has paramettes, surface, shaping, align and thickener one farthest ot left has power pose, tool settings and render settings
    I can't think of anything I done over the years that has gained as much ease of work has at least two monitors and usally three. ... for just offloading paletes they don't even have to be new expensive ones but the let you see the middle one at all times'
  • felisfelis Posts: 6,147
    My control icons move along if the viewport is resized, if expanging the right side.
    I think I had that once long time ago, but I cannot remember what I did to fix it. There might be a setting somewhere.
    Do you have a custom layout? If so I would suggest to save it.
    And then try to load a new layout Windows > Workspace > Select Layout, to see if the problem also is there.
  • prixatprixat Posts: 1,617
    The quick fix for the resizing bug was to remove the 'Shader Mixer' tab from the center view.
    960 x 578 - 40K
  • wscottartwscottart Posts: 447
    Thanks prixat, that was the solution. There certainly are a lot of bugs in Daz, but still so awesome.
