Strange issue with DAZ
Hya all, I have a serious problem.
For about a week I've been unable to render anything; My PC appears lock up about 40 seconds to a minute into the task. I'd just tried experimenting with volumetrics, so I made sure that they were switched off, but it made no difference. Yesterday I left it to its own devices and went out. When I came back 4 hours later I found it had kept working... but crashed after about 3.5 hours. In the scene I was attempting to create, I was using render settings from DA Big Ocean (Sunset Bloom) and Ultrascenery as a test. These are both items I've used before in far more complex work, yet they don't work now. THere was an interesting error message though which basically said that the fault was caused by Adobe Cloud, and to re-install or update AC. I tried that, and it makes no difference, though Adobe Cloud still "Goes Funny" when I try to render something, which is interesting, because I barely use it.
Today I tried using DForce, to find that THAT no longer works either. I suspect that DAZ needs a complete reset, But after uninstalling/reinstalling, my previous settings still come back. Can anyone tell me where the settings are kept?
Thanks in advance.
  • GranvilleGranville Posts: 700
    What does your log file say? You can find it in the help menu I think.
  • An awful lot, most of which I don't understand. "Warnings" and "Not initialised" stand out a lot. An example:
    2022-06-29 08:19:59.564 [INFO] :: Using GLEW 1.9.0
    2022-06-29 08:19:59.565 [INFO] :: Supported OpenGL extensions:
    2022-06-29 08:19:59.565 [INFO] :: GL_AMD_multi_draw_indirect
    2022-06-29 08:19:59.565 [INFO] :: GL_AMD_seamless_cubemap_per_texture
    2022-06-29 08:19:59.565 [INFO] :: GL_AMD_vertex_shader_viewport_index
    2022-06-29 08:19:59.565 [INFO] :: GL_AMD_vertex_shader_layer
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_arrays_of_arrays
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_base_instance
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_bindless_texture : NOT INITIALIZED
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_blend_func_extended
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_buffer_storage : NOT INITIALIZED
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_clear_buffer_object
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_clear_texture : NOT INITIALIZED
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_clip_control : NOT INITIALIZED
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_color_buffer_float
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_compatibility
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_compressed_texture_pixel_storage
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_conservative_depth
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_compute_shader
    2022-06-29 08:19:59.565 [INFO] :: GL_ARB_compute_variable_group_size : NOT INITIALIZED
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_conditional_render_inverted : NOT INITIALIZED
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_copy_buffer
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_copy_image
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_cull_distance : NOT INITIALIZED
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_debug_output
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_depth_buffer_float
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_depth_clamp
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_depth_texture
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_derivative_control : NOT INITIALIZED
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_direct_state_access : NOT INITIALIZED
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_draw_buffers
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_draw_buffers_blend
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_draw_indirect
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_draw_elements_base_vertex
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_draw_instanced
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_enhanced_layouts : NOT INITIALIZED
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_ES2_compatibility
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_ES3_compatibility
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_ES3_1_compatibility : NOT INITIALIZED
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_ES3_2_compatibility : NOT INITIALIZED
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_explicit_attrib_location
    2022-06-29 08:19:59.566 [INFO] :: GL_ARB_explicit_uniform_location
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_fragment_coord_conventions
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_fragment_layer_viewport
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_fragment_program
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_fragment_program_shadow
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_fragment_shader
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_fragment_shader_interlock : NOT INITIALIZED
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_framebuffer_no_attachments
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_framebuffer_object
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_framebuffer_sRGB
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_geometry_shader4
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_get_program_binary
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_get_texture_sub_image : NOT INITIALIZED
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_gl_spirv : NOT INITIALIZED
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_gpu_shader5
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_gpu_shader_fp64
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_gpu_shader_int64 : NOT INITIALIZED
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_half_float_pixel
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_half_float_vertex
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_imaging
    2022-06-29 08:19:59.567 [INFO] :: GL_ARB_indirect_parameters : NOT INITIALIZED
  • barbultbarbult Posts: 26,590
    Make sure your Render Settigs Instancing Optimization is NOT set to Speed if you are using UltraScenery. The Big Ocean preset might have done that.
  • Richard HaseltineRichard Haseltine Posts: 109,502
    Those relate to OpenGL, used by the Viewport Drawstyles except Iray and Filament.
    What are your system sepcifications, and what GPU (video card) driver version do you have? You might also check the end of the log after an attempt to render - you can open it without restarting Daz Studio by pasting this into a file browser address bar
    %AppData%/daz 3d/studio4/log.txt
  • I'll set up a render to get start to finish, though it may take a long time. My GPU is an RTX3060. I've downloaded the latest drivers (Tried both gaming and Studio), and then tried to roll back to previous drivers when that didn't work.
    I'll be back, and Thank you all for any assistance. :)
    You could attach the log to your post with the "Attach a file" above "Post Comment" button, and we could have a look.
    If a render takes more than an hour on a 3060, something is wrong or the scene is crazy complex.
    I have an 3060, and usually the renders take less than 30 minutes (Three G8 characters and architecture), one character alone doesn't take but minutes.
  • Actually, took much shorter to to crash. This is the session, again using the assets which have become a benchmark. It's several thousnd characters too long just to post it all, and can't be attached as a file, so here is the part pertinent to the actual render:
    2022-07-01 19:55:45.941 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2022-07-01 19:55:45.942 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
    2022-07-01 19:55:45.943 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2022-07-01 19:55:45.943 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2022-07-01 20:04:48.297 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 1 G triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 1 G triangles, 0 fiber instances yielding 0 segments) took 542.334 s
    2022-07-01 20:04:48.313 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating section objects.
    2022-07-01 20:04:48.338 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2022-07-01 20:05:12.732 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_UltraScene Terrain__Default_278_2' uses MDL JIT compilation.
    2022-07-01 20:05:12.760 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_USC Tree 08__Leaf_3b7_62666' uses MDL JIT compilation.
    2022-07-01 20:05:12.763 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_USC Tree 08__Trunk_3c2_62679' uses MDL JIT compilation.
    2022-07-01 20:05:12.767 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_USC Fallen Leaves 11__Material_1_609_63368' uses MDL JIT compilation.
    2022-07-01 20:05:12.798 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 41 textures, 8 lambdas (8 unique)
    2022-07-01 20:05:12.851 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
    2022-07-01 20:05:12.853 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2022-07-01 20:05:12.858 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2022-07-01 20:05:12.858 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2022-07-01 20:05:12.858 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2022-07-01 20:05:13.119 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2022-07-01 20:05:13.121 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2022-07-01 20:05:13.121 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2022-07-01 20:05:13.180 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2022-07-01 20:05:13.187 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2022-07-01 20:05:13.224 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler enabled
    2022-07-01 20:05:13.225 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2022-07-01 20:05:13.280 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 15 cores for rendering
    2022-07-01 20:05:13.286 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using OptiX version 7.3.0
    2022-07-01 20:05:13.618 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX for CUDA device 0
    2022-07-01 20:05:14.877 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 2 device(s):
    2022-07-01 20:05:14.877 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info :     CUDA device 0 (NVIDIA GeForce RTX 3060)
    2022-07-01 20:05:14.877 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info :     CPU
    2022-07-01 20:05:14.878 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2022-07-01 20:05:14.882 Iray [INFO] - IRAY:RENDER ::   1.14  IRAY   rend progr: CPU: Processing scene...
    2022-07-01 20:05:14.882 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3060): Processing scene...
    2022-07-01 20:05:15.011 Iray [INFO] - IRAY:RENDER ::   1.5   IRAY   rend info : Using Embree 3.13.2
    2022-07-01 20:05:15.012 Iray [INFO] - IRAY:RENDER ::   1.5   IRAY   rend info : Initializing Embree
    2022-07-01 20:05:46.793 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.6   IRAY   rend error: Unable to allocate 11.725 GiB from 972.578 MiB of available device memory
    2022-07-01 20:06:07.044 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.4   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Scene setup failed
  • felisfelis Posts: 6,148
    Why can't you attach the log as a file?
    I can see you are using ultrascenery. In Render Settings > Editor > Optimization, is your Instance Optimization set to Memory?
  • Felis, that appears to have done it, thank you :) I don't recall having changed any such setting but I found that the instance optimization was set at speed. Set it to memory and rendering is working fine now.
  • Thank you all for your contibutions.smiley As for why I couldn't attach the  log file; I saved it as an .rtf, which apparently is not allowed here. Printed out, it ran to about 40 pages so I'm glad we didn't have to go through THAT line by line. laugh
    Look at the message I posted here hours ago. I suggested that the Big Ocean preset changed you Instancing Optimization to Speed.
  • My bad, Barbult. Sorry.
