Weird jagged lines on figure after using Grasp Helper
doibhildoibhil Posts: 32
edited June 2022 in Daz Studio Discussion
This is the product: https://www.daz3d.com/grasp-helper-for-genesis-8-and-genesis-81
I used the product and then used the built in "remove" function, which theoretically should revert the scene to how it was before, but it left me with these weird jagged lines on my figure that weren't there before. I attached an image. Nothing I do seems to get rid of them other than reapplying the grasp helper. I tried adding a smoothing modifier but no luck. Any idea what the issue is? Any help is appreciated!
Post edited by doibhil on
  • Richard HaseltineRichard Haseltine Posts: 109,357
    You mean the terminator of the shadow on her arm? That is a terminator effect - check that the render division level is not lower than it was (Parameters pane under Mesh Resolution) and, if that is OK, try adjusting the light position slightly.
  • doibhildoibhil Posts: 32
    Thanks for the help! Messed around a bit mesh resolution. For some reason it was no longer set to high resolution, changed it back and problem was solved. Don't know why I didn't notice it before.
