Moon Mining Machine
This is still failing to download in dim
https://www.daz3d.com/moon-mining-machine
  • AgitatedRiotAgitatedRiot Posts: 4,590
    Is it the update that keeps showing up? I know sometimes it shows up and sometimes it doesn't.
  • HaruchaiHaruchai Posts: 2,027
    If it is then I'm glad to discover I'm not the only one. When it shows up, I have downloaded the thumbnails, and it shows the thumbnail for one of Polish's weapons packs. I think there is a glitch in the database somewhere causing a conflict, but the fact that it is intermittent is weird. I contacted support about it (with images) but they were unable to replicate the issue so I thought it was local to my machine.
  • NorthOf45NorthOf45 Posts: 5,692
    Couldn't replicate? I noted it two months ago, and it still pops up intermittently. I just ignore it, now.
    Same :)
  • Robert FreiseRobert Freise Posts: 4,574
    Yeah that's when I first saw it as well, and it is an update
    edited June 2022
    I use Daz Connect so I can have big thumbnails. Once I get the moon machine error in DIM. I get an update on modern military weapons which won't update Connect.
    Post edited by AgitatedRiot on
    edited June 2022
    It's back today. Also notice that in DIM the information i, just before the Download button, is in italics and gives an error 'Could not find local ReadMe' when clicked, never seen that before.
    646 x 591 - 201K
    Post edited by Haruchai on
    I got it today also.
  • reserv888reserv888 Posts: 1,164
    Maybe this is solved since forever, otherwise check if you have "Moon Mining Machine DS" under the Installed tab. The "Moon Mining Machine" (without DS) fails for me too, but I also have the "DS" version, as shown in the attached image. And yes, I can load the item in a scene.
    844 x 1080 - 367K
    Not solved, I still get it occasionally. It is the template file, which has no downloadable link in DIM. The wires got crossed somewhere...
    edited September 2022
    I also received this error. It has been going on for a while. After you get if you use Daz Central, you'll see an update for Modern Military Weapons 2 needs to be updated. It fails.
  • wsterdanwsterdan Posts: 3,063
    I contacted support about it a while ago; the issue I have is that the DIM package includes the templates, which should only be downloaded manually; I was told to download the package from my accounts page, which worked. I was told I shouldn't try to download templates using DIM, to which I advised them that I only picked what was there, that I didn't add the templates to the DIM package and that it should be fixed. Hopefully that'll ve fixed eventually. In the meantime, the log should show if it's still trying to download the Templates file.
    -- Walt Sterdan
    -- Walt Sterdan
    Thanks for that information, at least now we know why it's happenening, and yes, hopefully your more informative support ticket will get this sorted out.
