Setting a standard Backdrop colour DS 4.7
This is what I have tried.
Open Environment pane>select Backdrop from drop-down>select colour>Visible in render is on>close pane>save scene as Backdrop Colour.
Edit>Preferences>Scene>On New Load File>select Backdrop Colour file>Accept.
When I open a new project the transparent backdrop is present in renders unless I set the backdrop colour again.
Grateful for advice.
Do what you did then with your new background color go to WindowWorkspace/Save Layout. Name and save your new layout. Then make sure your new layout is selected under WindowWorkspace/Select Layout. Should work. Hope that helps.
Many thanks for the response. As far as I am aware this applies only to the workspace background and not the image backdrop.
That may be. Sorry I couldn't help
