Moon Mining Machine
Robert Freise
This is still failing to download in dim
Robert Freise
Is it the update that keeps showing up? I know sometimes it shows up and sometimes it doesn't.
If it is then I'm glad to discover I'm not the only one. When it shows up, I have downloaded the thumbnails, and it shows the thumbnail for one of Polish's weapons packs. I think there is a glitch in the database somewhere causing a conflict, but the fact that it is intermittent is weird. I contacted support about it (with images) but they were unable to replicate the issue so I thought it was local to my machine.
Couldn't replicate? I noted it two months ago, and it still pops up intermittently. I just ignore it, now.
Same :)
Yeah that's when I first saw it as well, and it is an update
I use Daz Connect so I can have big thumbnails. Once I get the moon machine error in DIM. I get an update on modern military weapons which won't update Connect.
It's back today. Also notice that in DIM the information i, just before the Download button, is in italics and gives an error 'Could not find local ReadMe' when clicked, never seen that before.
I got it today also.
Maybe this is solved since forever, otherwise check if you have "Moon Mining Machine DS" under the Installed tab. The "Moon Mining Machine" (without DS) fails for me too, but I also have the "DS" version, as shown in the attached image. And yes, I can load the item in a scene.
Not solved, I still get it occasionally. It is the template file, which has no downloadable link in DIM. The wires got crossed somewhere...
I also received this error. It has been going on for a while. After you get if you use Daz Central, you'll see an update for Modern Military Weapons 2 needs to be updated. It fails.
I contacted support about it a while ago; the issue I have is that the DIM package includes the templates, which should only be downloaded manually; I was told to download the package from my accounts page, which worked. I was told I shouldn't try to download templates using DIM, to which I advised them that I only picked what was there, that I didn't add the templates to the DIM package and that it should be fixed. Hopefully that'll ve fixed eventually. In the meantime, the log should show if it's still trying to download the Templates file.
-- Walt Sterdan
Thanks for that information, at least now we know why it's happenening, and yes, hopefully your more informative support ticket will get this sorted out.
