Gtx and Rtx possible?
Is it possible to use a 980ti and a 3080ti in daz? I am having issues with the 980ti rendering with the 3080ti installed. It will start without the 3080ti and finish a render.
It may well be that the 980Ti is running out of memory - non-RTX cards need more as they have to load extra code to emulate the RTX features.
Are there some settings I can mess with to use just the non rtx iray? I dont normally use the denoisers anyways.
The 980TI has just 6GB's of VRAM, and the baseload for OS, DS, Scene, "Working Space" and the emulation of RTX functions takes 4GB's, leaving just 2GB's for rendering, which isn't much.
The current Iray is designed for RT, there is no "non RTX Iray" anymore.
Maybe he's asking if there are settings for using just 3DL or Filament, instead of Iray??
Or maybe he doesn't realize he can de-select his 980Ti and just select the 3080 Ti for Iray rendering?
Sorry, I have a 3080 Ti, but I'm just getting around to rendering again, still not set up, so maybe I'm confused because it's been so long.
.. I'll bow out.
