Can I change the image in the TV for something else? have picture
foxyfoxfurriesfoxyfoxfurries Posts: 391
edited June 2022 in Daz Studio Discussion
Hey :)
Can I change the TV screen to picture I want like Tekken or some other game? if yes how?
I tryed to put some Tekken image in photoshop but I dont make it so perfect like it suppost to be  , It looks not so good.
Thanks ! :D
Post edited by foxyfoxfurries on
  • charlescharles Posts: 866
    It depends on the UV mapping and if the screen is it's own submesh.
    The maps for the monitor and screen maybe seperate (which is ideal) but they could be baked together. If they are baked together you have to edit the screen section with the image you want on screen. If they are seperate then just insert yours, however if the ratio is off you will need to nudge the materials vertical and horizontal positioning and maybe scale to get it to fit. This in itself may skew your image and you may need to crop it out and edit in photoshop to be the same as the original images aspect ratio.
  • marblemarble Posts: 7,500
    Great answer. I do all of those things. Occasionally you swap out the image and it renders flipped so you have to flip the original so the it appears the right way up when rendered.
    Ok thank you very much , the TV have prop to his own model BTW if its metter , I did it on photoshop but can I do it in the DAZ Studio as well? if yes how can I do what you said? Or I didnt understand right hehe
    BTW thanks! :)
  • felisfelis Posts: 6,149
    In Daz Studio, click the TV in the scene tab, and expand the surface tab.
    If the screen (image) has it own surface tab, click on that.
    If using Iray, then the image will probably be present in base colour, and potentially also emission.
    If you then click on the image in base colour you get an option for browse, where you can browse to where your wanted image is. It will likely be too large, but you can then, again after click on the image, select image editor, and adjust the scale and offset.
    If it is hard to get right, then you can take the original image in base colour into an image editor, and adjust your wanted image so it matches the original. After saving that, you can replace it in the surface tab, like described above,
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,597
    it depends entirely on how the TV is modelled
    if it has a separate map for the screen or an atlassed texture for the lot
    the later you will need to do in an image editor
    even if it does have a separate texture it depends on the UV coordinates how it fits
    I have many sets with the most weirdly UV mapped TVS
  • riverman63riverman63 Posts: 58
    If you cannot edit the the screen then just create a primitive plane the same size and place it over the existing screen, then apply a .jpg of your choice as the surface...
    First of all thanks for ALL OF YOU!!!! I dont know how to note you all together but YOUR ALL AWESOME WITH GREAT ADVICES!!! THANKS!
    About the screen I have some settings to that , also it likes all the other stuff I have? like If I want to add Jordan logo to shirt or pants I can do it in the same way?
    1319 x 857 - 737K
    Yes, it is the same procedure.
    Although if you want to add a logo to a shirt, you could also instead do it with layered image editor. That works like simple layers in an image editing programs.
    Thank you all so much and thanks for the idea and help! I try all you guys say to me and if I will have more question I will open new note , I will try to search in google and youtube how to make it right :)
    Thanks all for everything!!!! :)
