Deleted My DAZ Connect Library
Deleted My DAZ Connect Library since I never use Connect and all works fine except Daz Default Resources are missing.
I do not want to install it via Connect so, can I download it manually and install it manually.
I looked, but I can not find it, unless it is in G8F and / or G8M Essentials?
    edited June 2022
     They are in with your Daz Studio Program's files: https://www.daz3d.com/downloader/customer/files#prod_13176
    IM00013176-42_DefaultResourcesforDAZStudio420.zip    39.5 MB
    Post edited by Catherine3678ab on
  • PetraPetra Posts: 1,157
    IceCrMn said:
    Should be here.
    You are a STAR, now I can install it the way I like to install content without DIM or Central or Connect.
    I will uninstall the default Resources that I installed with DIM a short while ago. :)
    Not all the files go into the content library, some need to go in folders that are Studio 'system' folders.  It is best to use DIM to install shaders and plug-ins.
    Yes, I left it installed with DIM, I have Daz Studio installed with DIM too.
