Adding to Cart…
Symlinks working so far and it's super quick to setup! i moved mydaz library and my library over to another 1tb ssd. left my main ssd with almost 1 Tb free now! zip backups moved off also to the cloud for safekeeping.
The other method seemed too daunting and time consuming for my tastes.
Thanks a bunch!
Hi guys,
I've many custom material presets and also many custom figures that now use textures located in C, what happens to them if I move DAZ to another hard disk?
I work with DAZ since 2016 and I'm terrified of losing all my work
As long as Daz Studio knows where your content is located, it can access it and load it. This is done via the Content Directory Manager.
The WP Guru explains the process briefly in at least two of his YouTube videos:
Thank you! My internal Hard Drive was cluttered and now I have room.
...as the Daz content and scene library are simply data, it should be easily transferable to a new drive.
To preserve the old default drive designation (say, drive "D") so as not to break the Daz programme, IM install, and plugin paths. wouldn't it be simple just to move the current drive to another port connection (say "E" in this case) install the new drive on the connection to the port for "D", then move the Daz content and scene libraries over to the new drive?
