VRAM Tool?
in The Commons
Noob question pls dont hurt me....
Is there any tool/plugin for daz for measuring currrent VRAM usage on the scene?
If your using windows the Task Manager will have a GPU section under Performance.
Dedicated GPU Memory will show % used.
Another tool you can download free is called GPU-Z.
If you are wanting to know how much VRAM the scene will take to render in Iray, before rendering, then I'm afraid that isn't possible.
Download/Install MSI afterburner, not only does it have everything you need to monitor your GPU via OSD, but you can also directly control your GPU fan via the program!
