How to make Gen 8.1 support cutout opacity? option is there except it doesn't work
I'm beyond disappointed to find out that UV & skin parametes along with many other things are vastly different between 8.0 & 8.1, why bother give 8.1 a cutout opacity option when it doesn't even work?
  • Richard HaseltineRichard Haseltine Posts: 108,620
    The difference is the shader used, not the figure - PBR Skin vs Iray Uber base. Switching shader will give you different properties, but will change the way the skin looks.
  • windli3356windli3356 Posts: 291
    I just found out, cutout opcaity works on all 8.1 female, but not for certain male mat, regardless what shader properties I choose, debug team might want to know this.  (works fine on all gen8.0 male/female)
