what skin did I use
KeithH
Hi -
I changed the skin material and do not remember which one I chose. How do I lookup what skin material my model is using?
Thanks
KeithH
Hi -
Thanks
If it's a Daz product installed with metadata you could use http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/metadata/list_products_used/start
Otherwise, open the Surfaces pane, seelct the figure, select one of the skin surfaces in the Editor tab, and look at the path for the base Colour (Diffuse Colour if it is using a 3Delight shader) - you can see this most readily by hovering over the namo-thumbnail. With luck that will at least narrow it down, and usually will give the artist and character names.
This worked - thank you
