WOW... Feng Adelia HD for Genesis 8.1 Female
This is just a beautiful character.... an older, beautiful woman... so realistic, perfect for many scenes.
Thank you so much.
    Yeah really high quality! Noticed that one too.
  • WebsoulWebsoul Posts: 221
    Feng Adelia HD
    Yeah the character looks very realistic, I've put it on my wishlist for later
  • GordigGordig Posts: 10,677
    As I said in another thread, I definitely wasn't expecting those shredded abs when I clicked on that thumbnail. It's definitely a great character.
  • HylasHylas Posts: 5,283
    Those abs don't look right. Give her Ellithia's body and you're good to go.
    Skin looks great!
  • What's the trick for making muscle definition more prominent on renders for 8.1 figures? Surfaces seem different compared to 8 figures.
  • richardandtracyrichardandtracy Posts: 7,512
    Level 5 HD...
    My PC's wimpering. Lovely detail, but at what cost in clock cycles?
    Regards,
    Richard.
  • tsroemitsroemi Posts: 3,529
    Has somebody tried turning down the subdivision a bit, does she still look realistic on level 3 or something more useable for weaker PCs? I'd love to get her, but I'm afraid I won't be using her much at level 5.
  • DandeneDandene Posts: 162
    I was so impressed when I saw her.  The variation of color and detail in her skin textures are what drew me in hehe.  She was immediate add to my wishlist (if I hadn't spent so much this month, I'd already have her!).  cheeky
  • FSMCDesignsFSMCDesigns Posts: 12,851
    Apparently not that high of quality. A friend that has her just sent me an image of the nipples misaligned with the texture asking if I knew what was wrong. I told him to check on a base 8.1 and he got the same results. Anyone else see this?
    Not surprising. There are a few G3F-G8F characters like that. I would blame both the PA for not checking this & the skin resources they used. I guess the only way to fix something like that would be to use Substance Painter or Blender, which probably a lot of us don't use. When it comes to things like anatomical elements & nipple areas, I don't think its considered much of a priority in regards to making sure the textures match or are placed correctly.
    I remember purchasing a G3 character from a top PA and it had the same issue and the PA posted saying they never did nude renders. Personally, I don't care if a PA does nude renders or not, things like that should be perfect regardless, otherwise they should move to creating something else like environments, etc.
  • PixelSploitingPixelSploiting Posts: 898
    edited June 2022
     I mean, a slight misalignment is fixable in PS using stacked linked layers for diff/bum/spec/normal and a UV template layer on top... But that's a lot of layer massaging and I don't think that many people purchasing any products would bother nor think that having Adobe subscription "juuust in case" any products had small flaws should be mandatory. wink
    Better hidden things that obvious ones like navels, though.
    Edit:
     Even better, textures without nipples on them at all. If the figure is not meant for nude renders.
    Post edited by PixelSploiting on
  • markusmaternmarkusmatern Posts: 605
    edited June 2022
    This happens with the G8.1 default nipple morphs. The character has a separate nipple morph that works fine.
    Post edited by markusmatern on
    That sounds like a work around. One is stuck with whatever that morph provides, no fine tuning possible with any other nipple related morphs.
  • lioncrudlioncrud Posts: 29
    does anyone know the neme of Feng's hairstyle in the main promo photo of her?  I cannot find it for the life of me: https://gcdn.daz3d.com/p/86297/i/fengadeliahdforgenesis81female00maindaz3d.jpg
