Can a spotlight be "shaped"
ScavengerScavenger Posts: 2,674
Can you shape a spotlight, like, use the scale controls to make it long and flat rather than just conical?
Like in the screen shot, the spotlight is on the right side, so there's a bit of a "hotspot", I'd like to spread it across the band,
  • Richard HaseltineRichard Haseltine Posts: 108,982
    The basic spotlight doesn't have many options. The uberSpot does have barn doors, "flaps" that can constrain the light, but it's still emanating from a point. If you want an extended source your only real option is an area light applied to a surface - the uberArea light shader is included with DS.
