How to move or delete the whole column of keyframes on timeline?
James
Well, I know there are small T's that can be selected and moved or deleted, but what if I need to select the whole column.
It's frustrating to find these T's.
Post edited by James on
For now, if you collapse the property entries in the Timneline's Dopesheet that have the keys you want to use then there will be a single, triangular, key-marker that you can move or delete to affect all of the keys it represents.
If I need to select the whole column, how to do that? Or is it not possible?
The method I gave should let you select all keys to whatever level you collapse the hierarchy.
