How to delete categories added to the menu bar
I have these 2 items I added to the menu bar that I would like to remove but couldn't figure out how
thanks for the help
  • felisfelis Posts: 6,507
    Not sure what you mean by added.
    To me it looks like you have changed the area that default is properties to a second viewport. To change that you can click on the icon in upper left corner and select whatever you would like to have in that area.
  • Richard HaseltineRichard Haseltine Posts: 111,399
    That looks like Blender, not Daz Studio - and nothing inside that circle is a menu bar so it isn't at all clear what you are asking about.
  • VicSVicS Posts: 1,273
    wrong image , here it is,  sorry
    1517 x 1177 - 3M
    Well, I don't know what exactly added them but assuming theya re static rather thna added by a plug-in yiu should be able to remove them through the Window>Workspace>Customise dialogue, in the Menus tab on the right under Main Menus (right-click has the remove option).
    cant see where to delete them, I saw one called pose mixer which is the vdigitimes menu bar but it did not delete it after I chose remove
    can you maybe send me a screen shot where exactly I should look or click, thanks
    2246 x 1917 - 818K
  • DoctorJellybeanDoctorJellybean Posts: 10,110
    Try  Window - Workspace - Update and Merge Menus to refresh the UI.
    If not I said to look in the Menus tab, you were in Toolbars.
    Doctor's tip deleted one but left content tab, under menus when I right click content there is only option to add , underneath the header "content" things can be deldeted but not content itself
    thanks
    That is the Content pane's option menu, you need to look under Main Menus
    im looking but cant find that Richard, can someone send me a screen shot perhaps?
    thanks
    In the Customise dialogue go to the Menus tab. One of the entries should be Main menu (or Menus). Under that you shold see the top-level menus from the main bar, File, Edit, etc. - including the ones added by whatever it was. Right-click those entries to remove them.
    I have the same problem, but when I click with right button I have only two options: "add submenu" and "add separator".
    I can't delete any instance
  • What are you right-clicking on? A command or a menu (top-level or sub)?
    In the menus section on the right. It's a voice with a + on the left
  • A voice? perhaps you could post a screenshot.
    I don't know how, but I have deleted the voice frown
    Thanks
