Nightmare! All files in my Content Library Categories have disappeared. HALP!
2»
  • Saxa -- SDSaxa -- SD Posts: 880
    RKane_1 said:
    HUZZAH!!! PROBLEM SOLVED!
    Awesome!
    If thias happens to you, first make asure that ALL Windows updates have completed. Then check your cirectory.
    So what was the fix? Was it just an incomplete Windows update?
    If that doesn't work, then reinstall both DAZ and PostgreCMS.
    I AM SO HAPPY IT'S ALL BACK! ALL RECOVERED!
    Happy for you too!!!
    That's one of the reasons I really don't like Windows updating without notifying us first. I often disconnect from the net and if it's half done a task, that is not good.
    Cheers!
  • NorthOf45NorthOf45 Posts: 5,709
    Cheers!
    Second Tuesday of the month is Microsoft Update day, unless there is an urgent patch.
    Okay, thanks, C.
  • ShelLuserShelLuser Posts: 749
    I am aware that OP solved his issue (fortunately!), but still wanted to comment on this:
    kyoto kid said:
    ...try this:
    Open Windows Task Manger and go to the Services Tab.  There should be an entry labelled DAZContentManagement.
    This isn't always the case, my setup for example does not use a dedicated service (probably because I still rely on DIM instead of Daz Central). So you can't really rely on this.  You can also check the 'Processes' tab, find the "Daz Studio Application" section, expand it and it should also list "PostgreSQL Server", if it does it means that the CMS is running.
  • Richard HaseltineRichard Haseltine Posts: 108,459
    kyoto kid said:
    ...try this:
    Missed this. it is referring to the Valentina database, which was an always-on service. Daz Studio has not used valentina since 4.9, and dropped it as the default (in favour of PostgreSQL) before that. I have added a note to the post to try to avoid future confusion.
  • possible prevention for future issues
    Way back on day 1 somewhere in 2007 I didn't like the way everything was stacked
    I have 50 folders ... each with a specific kind of product installed in it (DIM will do it)
    recommended daz folder for 1 ...
    then clothes, people, hair, cars buildings  (okay I have 20 levels of building by history and style etc)
    but each folder is imported into my content library.
    since I have copies of the entire drive I can never lose the way I've arranged my content.
    I've posted pictures of the stucture in the past but righ now pictures will not upload.
